Traction Bar Length.....
Old May 12, 2008 | 11:40 AM
scarecrow's Avatar
Default Traction Bar Length.....
i am going to make a set of bars. what is a good length for all around use.. street , drag , pullin , towing....????
Old May 12, 2008 | 04:50 PM
slowtowpig's Avatar
longer the better right?
Old May 12, 2008 | 05:32 PM
DangerousDuramax's Avatar
No, and in fact with most cases you want them shorter. The longer the bar the more flex it has but the object is to keep the wheel arc the same as stock so you want a bar long enough that there is no binding in a full range of motion but short enough that it actually transmits the power to the ground.
Old May 12, 2008 | 05:59 PM
Here is a link that gives a really good explanation as to how traction bars work with your rear geometry.
Axle Wrap Prevention
Old May 12, 2008 | 06:02 PM
slowtowpig's Avatar
great site
Old May 12, 2008 | 07:27 PM
cbrahs's Avatar
check this out.
Old May 13, 2008 | 09:11 PM
Uncle Bubba's Avatar
If you all will indulge me here makin the ultimate sin of cuttin on somebody elses thread, hate to start another since there is a few goin on already on the same topic.
I'm lookin at this project and wondering what the thoughts are on building these bars so that they attach around the axle on one end and using a longer bolt on the leaf spring mount to mount the front of them to. Just put a barrel over the threads so that they don't buggar up and use a heim joint over the barrel. Good, Bad or just no way in hell.
carid
Diesel Bombers Sponsors
Sep 2, 2015 06:56 AM
1ATony
1A Auto Parts
Jul 29, 2015 12:54 PM
mark402001
Jan 18, 2015 03:17 PM
12vbomber
Nov 11, 2014 10:58 AM
motormayhem
Nov 1, 2014 01:24 PM
