1995 power stroke
Old Jan 30, 2015 | 09:19 AM
Brad.julie's Avatar
Default 1995 power stroke
Good morning folks
I have a 1995 power stroke with reman injectors I replaced 8 while only one was bad .
I have a hard time starting my truck . I have replaced the solenoid glow plugs starter battery's
Any help is appreciated I also have a edge programmer and my truck will run on stage 1 but does not like 2 or 3
Old Jan 30, 2015 | 09:48 AM
joebob3093's Avatar
Moderator
where did you get the injectors? how many miles are on them? what brand injector O rings did you use?
Old Jan 30, 2015 | 10:09 AM
Brad.julie's Avatar
I got the injectors from diesel care and performance out of Memphis tn and I used there I rings maybe 5000 miles on them now
Old Jan 30, 2015 | 10:54 AM
joebob3093's Avatar
Moderator
did they build them? powerstoke injectors are very picky and i will only trust a couple builders in the country. find out what O rings they use because you should only use alliant brand rings.
i guess before i ask anything else what is it doing to cause a hard start?
Old Jan 30, 2015 | 11:13 AM
Brad.julie's Avatar
They rebuild them there selves in there diesel machine shop
And hard start just takes forever to fire I put a new lift pump didn't make any difference went as fare as to drop the tanks and check pickup tubes
Old Jan 30, 2015 | 12:19 PM
joebob3093's Avatar
Moderator
So just cranks but takes a long time to fire?
Old Jan 31, 2015 | 08:43 AM
Brad.julie's Avatar
Yes that is correct takes long time to fire my edge programmer says it has plenty of ICP pressure
Old Jan 31, 2015 | 11:30 AM
joebob3093's Avatar
Moderator
Pull the plug at the top of the reservoir and see it it has oil all the way to the top. My guess is you have a oil issue
Old Feb 6, 2015 | 01:48 AM
detroitdiesel idi's Avatar
diesel care is junk so is Pensacola and injectors directy buy oem only or alliant power same thing you can get oem half price on ebay than you can get at the stealer ship.. diesel care is just a horrible company no matter how u slice it
Old Feb 6, 2015 | 04:46 AM
joebob3093's Avatar
Moderator
I had never heard of them and because of that I was leaning towards a bad build on the set of injectors causing all the problems
Sep 21, 2015 08:00 AM
powrrstrokee
Apr 18, 2015 12:24 PM
Dec 10, 2014 08:10 AM
Oct 13, 2014 08:10 AM
