Ford Powerstroke 08-10 6.4L Discussion of 6.4 Liter Ford Powerstroke Turbo Diesels
Gut the DPF?
Old Jan 25, 2015 | 01:53 AM
Dr.G's Avatar
Default Gut the DPF?
I'm thinking that you should be able to gut the OE DPF filter and use a resistor in place of the temp. and pressure sensors in order to fool the ECM. I'm really not sure if you would need to do anything because theoretically the pressure sensor is what triggers the regeneration cycle and with the ceramic filter busted out of it there should be no pressure build up to cause it to go into the exhaust cleaning mode. Thoughts or ideas anyone? Are there any plug and play simm's for the Ford 6.4 DPF sensors?
Old Jan 26, 2015 | 12:15 AM
97cummins's Avatar
I don't believe that is possable.
There is more involved in the dpf cycle, and the egr is also tied into the system also. And you would need the proper programmer to fool the sensors.
But it would be fun to find out if your thought would work
stillcummin
Feb 18, 2016 08:13 PM
sleepysubie
12
Jun 23, 2015 02:21 PM
97 stroker
Feb 18, 2015 03:25 PM
mrweasel
Oct 25, 2014 05:47 AM
jmed795
Oct 7, 2014 03:51 AM
