low dollar lift pump
Old Jan 23, 2015 | 10:36 PM
greenbomb's Avatar
Default low dollar lift pump
looking for a lift pump cause everyone says I need one I found that the diesel vans used them as they came out of the factory . Got one for $250 . It came with fuel return cooler . pump , filter all hooked up to a factory bracket. . Not sure I can put out a name here but its a dirtydiesel type pump. The pump is blow though type so if it went out the bosch pump could still suck through.. Being its a factory design it will most likely last forever . The filter is stock duramax type with the water drain and sensor . and the pump has a water drain on it too .. Almost looks like the pump has a filter in it . but not sure. Anyway its all mounted in a box like bracket that resembles a refrigeration unit , about 10 inches high and when placed up against the floorboards it fits flush with the bottom of the frame rails except for the filter drain . which could be moved up by redrilling the filter mounting holes. OR the parts could be removed and mounted separately .
Just FYI Im mounting a 2 micron Cat filter in the stockers place
landon025
Sep 8, 2015 09:21 PM
Renteria1217
Apr 16, 2015 11:38 PM
robbyS
Apr 16, 2015 02:22 PM
klein444
Feb 21, 2015 10:33 AM
moneypitk5
Feb 12, 2015 11:01 AM
