Removing Steering Stabilizer
Old May 11, 2008 | 07:11 PM
ChinookFE's Avatar
Default Removing Steering Stabilizer
My steering stabilizer is dented and I think it has something to do with the shake that my truck has developed....I have a new one and yesterday I went to pull the old one off and the stud end would not budge from the tie rod. I tried beating it with a hammer, no luck, so I put a pitman arm puller on there and started cranking down on it, the puller pushed a big divot into the top of the stud almost 1/16" deep, still nothing, and now the head of the studed end is mushroomed out to where I can't put the nut back on...Any idea on getting this thing off?
Old May 11, 2008 | 07:25 PM
Uncle Bubba's Avatar
If your talkin about the shock on the front axle you can go without it as long as your not runnin the big oversized tires. It just absorbs some of the jerkin of the steering wheel over the bumps.
I ran without it for a while why I fabricated a new one to fit and din't have any issues. They do make aftermarket ones that don't use the stock mounts though.
Old May 11, 2008 | 07:26 PM
ChinookFE's Avatar
Yeah...I have a new one, but I can't get the old one off...
Old May 11, 2008 | 07:31 PM
2500HeavyDuty's Avatar
pickle fork and a big hammer?
Old May 11, 2008 | 07:33 PM
ChinookFE's Avatar
Tried that too, also tried heating it with a torch
Old May 11, 2008 | 07:39 PM
shoot it off
pickle fork hasn't failed me yet, sometimes it takes 20 minutes of hammering but i get it
Last edited by 2500HeavyDuty; May 11, 2008 at 07:39 PM. Reason: Automerged Doublepost
Old May 11, 2008 | 08:36 PM
Body grinder get's anything lose. Has never failed me yet.
Old May 11, 2008 | 09:34 PM
Diesel-N-Dust's Avatar
My truck has not had a stabilizer since it was lifted, No problems. I feel that steering stabilizers are a "Band-aid" fix .JMO.
Old May 11, 2008 | 09:38 PM
Off road or nasty road you will feel the difference but if your drivin around town or just down the highways it's just extra weight.
Old May 12, 2008 | 08:47 PM
ChinookFE's Avatar
Well...Something beyond just the stabilizer is messed up in the front end....The thing started shaking on me so bad on the way home from work that it ripped the steering wheel out of my hands...Did it to me 11 times in 20 miles...It did it before the leveling kit and it seemed to go away all together after I put the leveling kit on, but now it is back with a vengence. I'm scared to drive it.
I was just out there messing with it some more, I jacked the truck up to tug on some stuff and see if I could find anything loose. The only thing I found was that if I grabbed the pitman arm and pulled on it, the output shaft from the steering gear would move a slight bit, maybe 1/32"-1/16" in the forward-aft direction, I've never paid attention enough to know if that is normal or not, but I imagine it isn't, could this be the source of the Death Wobble?
