2000 cummins hard start and smoke on startup.
Old Jan 14, 2015 | 01:56 PM
gator515's Avatar
Default 2000 cummins hard start and smoke on startup.
2000 dodge Ram 3500 4WD 1 ton duelly. Stock as far as I know. 236500 miles, daily driver, usually around 20 miles to work and back, a little more on weekends.
Just started, usually just flip the ignition key over motor cranks with just a little black smoke. Started yesterday, did not want to start, turned over several times, when it did start, had a miss, for a couple seconds, with white looking smoke. My first thought is leaking head gasket, or leaking something. Have not added water, or oil. Checked oil and it had a greenish tint to it. Oh, and its been colder than usual here for the last couple weeks, if that matters. I am new to diesel ownership, but many moons ago, about 30 years ago, was a mechanic. Things have changed and are a lot more complicated. Thanks for any input.
Timglow546
8
Jun 3, 2015 10:13 PM
Josh Chretien
5.9L 12V Performance
Mar 1, 2015 06:00 AM
trab123
Feb 9, 2015 09:44 AM
rschriek
Jan 26, 2015 07:30 AM
Domrig13
Dec 12, 2014 01:24 PM
