no go
Old Jan 4, 2015 | 07:11 AM
gordonsplinter's Avatar
Default no go
my 2000 ford powerstroke ran when it was parked after setting for 6 years it failed to start we soakd a rag with gas and put it over the air intake and it started and ran until gas all evaporated then it died could this be a bad fuel issue or what than you for your time
Old Jan 4, 2015 | 04:30 PM
AHolt's Avatar
Check your fuel pump to make sure you have fuel to engine.
Old Jan 6, 2015 | 11:46 PM
Rangmar's Avatar
7.3 will lose there hpop prime some times. On the top of the engine in the front there is a aluminum (box). Right above the high pressure oil pump. There is a small Allen screw remove it use a funnel and pour some oil in then on both heads there are 4 bolts per head remove 1 on each side pour oil in until it won't hold any more put them all back on and it may take some cranking but it should start.
