broken piston ring
Old Dec 25, 2014 | 08:45 PM
detroitdiesel idi's Avatar
Default broken piston ring
Customer came in with a 95 6.5 dually said it was smokin g some on startup..took a touch more cranking to start cold then normal. Original plan was timing chain tdco relearn and injectors and pmd relocation. Then I discovered it had tons of blow by so customer gave me go ahead for a rebuild. I yanked the motor tore it down and found a cracked head on drivers side that had coolant seeping out and top compression ring on #8 piston was broke and oil ring spring came out and went in oil pan!!! Thought I'd share this with you all
Attached Thumbnails broken piston ring-img_20141225_211641745.jpg   broken piston ring-_20141225_214018.jpg
Old Dec 25, 2014 | 08:46 PM
Truck had 160,000 miles
Old Dec 26, 2014 | 04:08 PM
Mayhem's Avatar
Bummer I would guess you will be looking for another block then.
Old Dec 26, 2014 | 07:38 PM
Nope block is in good shape just rings need replaced and camshaft
Old Jan 2, 2015 | 09:08 AM
racer55's Avatar
What happened to the cam?
Old Jan 2, 2015 | 02:07 PM
Had friction pits on front cam lobes
Rclemson
Ford Powerstroke 2011-Up 6.7L
Jul 26, 2015 04:10 PM
Locoster
Jul 6, 2015 03:35 PM
Chadpando
Jun 25, 2015 04:00 AM
CumminsAtYa
Mar 28, 2015 06:36 PM
tabascom16
For Sale
Nov 28, 2014 01:48 PM
