Alternative Fuels , Additives , Fluids Diesel Fuel, Off Road Diesel Fuel , Bio Diesel , Synthetics , Oils , Lubes , Fuel Additives , Emulsifiers , Demulsifiers , All Alternative Fuels , Additives and Fluids
Heating Times And Temps
Old May 11, 2008 | 07:40 PM
PhatB's Avatar
Default Heating Times And Temps
For those making their own Bio, if you would, please tell me your heating times, temps, size of your processor, and wattage of your heating elements.
I am in the final steps of designing my system, and would like to get some real world numbers to help me decide on final designs for heating.
Thanks in advance for any input.
Rick
*BUMP*
Anyone?
Old May 11, 2008 | 07:48 PM
2500HeavyDuty's Avatar
Hmm can you tell us more about your set up?
Old May 11, 2008 | 11:40 PM
PhatB's Avatar
I do not have one yet, but the first design plan is using two 55 gallon drums welded end to end to make a 110 gallon reactor. The same setup for the dry wash tank. Both will be modified into a cone bottomed tank. I will heat through a heat exchanger that I will build based upon the info I get from here and other sites. after dry washing with Magnesol, I will filter into a 330 gallon IBC storage tote through a series of bag filters, final filtering through a 1 micron filter.
Old May 11, 2008 | 11:51 PM
what other site r you getting this info from.
i think some guys on this site are already making their own bio, or getting it from a friend.
they just need to chime in
Old May 12, 2008 | 02:31 AM
PhatB's Avatar
cumminsforums.com , 4btswaps.com , turbodieselregister.com , dieseltruckresource.com
Old May 12, 2008 | 09:27 AM
jdugie123's Avatar
I was usually heating my oil to at least 140 before I started my reactions I never measured the temp after that. I use a band heater for a metal drum but I don't think it is the best solution it is causing a hot spot so I a looking for something new I hope to have my setup back and running by the end of June
ctd04x4
Sep 11, 2015 03:50 AM
