Duramax LMM codes and injection
Old Dec 14, 2014 | 08:36 PM
Renowest48's Avatar
Default Duramax LMM codes and injection
Completely stock 07 Lmm Max 4x4 with 200,000 miles it had a injector knock on #6 that was initially diagnosed by the previous owner as a rod knock when I purchased it. I have checked the harness but with all the codes its not isolated to the knocking #6 injector. Any thoughts?
Code P244b- DPF over pressure
P0300- Random missfire
P0206- Open injector #6
P0208 Open injector #8
P0303 Cylinder #3 missfire
P0301 Cylinder #1 missfire
I am also seeing fuel seep out around the EGR valve and am assuming its from over fueling of the stuck injectors.
I un-hooked #6 injector and the knock is gone. I have checked for harness rubs and cant see anything but if there is a prone area on the lmm please let me know.
I am just trying to gauge if I should tackle it myself or take it to a shop if I am going to need a tech II to diagnose the codes. I am hoping I can find the cause, swap the bad injectors, change the fuel contaminated oil and take it in to have the injectors calibrated saving me money.
Thanks,
Terry
dwmeehan
Jan 29, 2025 12:13 PM
moneypitk5
Feb 12, 2015 11:01 AM
