6.5 acts like low fuel in tank.
Old Dec 14, 2014 | 01:55 PM
Phoenixforsigns's Avatar
Default 6.5 acts like low fuel in tank.
My '96 Chevy C3500 6.5L is acting like it's almost out of fuel and when I "wiggle" it back and forth it smooths out for awhile. Both tanks are full, filter is new. It's now occasionally not starting. Ever since I had the heads replaced (3 mos ago) my fuel gauge hasn't been working properly. Don't know if it could possibly be related or not. Please help. Gus
Last edited by Mayhem; Dec 14, 2014 at 03:16 PM. Reason: No Phone numbers on open forum
Old Dec 14, 2014 | 05:44 PM
burnhedge's Avatar
Wiggle what? Getting good flow out the t - valve? If not test the lift pump. Check that your fuel cap is venting. Possible dirty sock filter in the tank.
Old Dec 14, 2014 | 10:50 PM
detroitdiesel idi's Avatar
X2 on fuel sending unit sock
Old Dec 15, 2014 | 08:53 AM
Floyd400's Avatar
This!
Old Dec 15, 2014 | 09:11 AM
Default Acts like out of fuel
When I wiggle the truck back and forth while still driving down the road.
Old Dec 15, 2014 | 09:12 AM
Default http://www.dieselbombers.com/chevy-gmc-6-2l-6-5l/124854-6-5-acts-like-low-fuel-tank.h
Thank you, I'll try to drop the tank and check that filter.
Gus
Old Dec 15, 2014 | 10:50 AM
Floyd400's Avatar
Gus
Don't forget to check lift pump and fuel tank cap for proper venting first. If the sending unit has been replaced before, it's very likely it has the wrong tank sock (strainer) on it. Diesel and gas used different strainers but it seems all the aftermarket senders come with the smaller gas sock installed. Otherwise, if you got a batch of really bad fuel or something, even the correct diesel sock will plug up. The diesel sock has a bypass in it that will still allow some fuel flow if it gets plugged or the fuel gells or whatnot.
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
