Powertroke wont start
hi everyone. I have a 1995 f250 7.3 powerstroke. I blew an high pressure oil line at high rpms, replaced it, ran the **** out of the truck 'til all the air was out of the hpop. I washed the oil from under the hood, cause it was a big mess, then I parked it. the next morning I started it up and ran as it should, I got a mile down the road and it lost all power and after a couple seconds died. I tried to start it but all I could get from it was a little pop every few second of cranking. later that night I cranked on it for a while and got it to fire but it was running on probably 2 cylinders and if I tried to rev it would die. today I hooked a scanner to it and it said the icp sensor was low of voltage or something in that neighborhood. but I unplugged the icp and it still wouldn't run. also it said that the sgc singal was bad and the kam internal control module error. I need hel. this trucks been sitting since october and I need it. thank you for your time and help.
I'll try that tomorrow. And how do I figure out if fuel is getting to the cylinders?
Oh now I feel like an idiot BC I knew that... And back went it broke down it was smoking white. Heavy white while cranking
I will. Thank you!
Cavnar
Sep 9, 2015 07:18 PM
cjgregory
Mar 31, 2015 01:45 PM
ronstop
Feb 26, 2015 09:48 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
