Lb7 wont idle
Old Nov 16, 2014 | 07:06 PM
DanielC559's Avatar
Default Lb7 wont idle
Hello everybody, I'm new to DB and wanted to get some input on my situation. I bought a 2004 duramax that wasn't running for pretty cheap. It had fuel pressure codes, egr codes, and glow plug codes. I replaced the CP3 pump, egr valve, egr sensor, all 8 glow plugs, glow plug module, glow plug relay, and fuel filter on it. The only code it has left is the glow plug one p0380. I have to start it with gasoline and once started it won't idle by itself I have to keep the gas pedal pressed a little so it won't die. It also smokes when i put it at high idle. Any help from you guys would be much appreciated. Thanks
Old Nov 17, 2014 | 02:07 PM
2500HeavyDuty's Avatar
what color is the smoke, does it smell like fuel?
Old Nov 17, 2014 | 02:24 PM
DanielC559's Avatar
Smoke is white and it does smell like fuel.
Old Nov 17, 2014 | 02:34 PM
injectors... all 8
Old Nov 17, 2014 | 05:40 PM
DanielC559's Avatar
Is there a way to isolate the bad ones?
Old Nov 17, 2014 | 06:07 PM
you can do a balance rate test and return rate test
Old Nov 17, 2014 | 07:01 PM
DanielC559's Avatar
I would need a computer hooked up to the truck for the balance rates and individually cap off each injector for the return rates right?
Old Nov 18, 2014 | 11:38 AM
return rate test u need graduated cylinders that read ml, and special fittings that connect to the return line side of the injectors and you gotta have the truck cranking with all the fuel lines connected besides the return lines and measure the fuel that comes out and see if it is within spec.
computer/scantool is needed for balance rate test
Old Nov 21, 2014 | 06:59 PM
2004LB7's Avatar
wouldnt white smoke indicate stuck injector?
if it was me i would pull the glow plugs and the FCIM fuse and crank it over watching which glow plug holes has fuel coming out
MechanicalDiesel
Aug 11, 2015 08:14 PM
duramaxtuner
LB7 Performance
9
Aug 5, 2015 11:36 PM
jordanokc
Feb 8, 2015 03:59 PM
cdetterer
15
Dec 8, 2014 08:46 PM
JMC23
5.9L 24V Performance
Oct 28, 2014 11:03 PM
