Diesel engine braking idea
Old Nov 13, 2014 | 01:13 PM
Joel Steven's Avatar
Default Diesel engine braking idea
Exhaust brakes are available for diesels to help get down long steep grades safely without cooking the brakes. They work by choking off the exhaust flow, turning the engine into an air compressor. But they are expensive and I have heard that they can be trouble prone due to carbon build up.
Gas engines have decent engine braking, just by closing the throttle valve, cutting off the air flow into the engine, turning it into a vacuum pump.
So how about installing a big throttle valve on a diesel at the turbo inlet, or on the intake manifold inlet for use as an engine brake? Is there any reason that wouldn't work? It seems that it would be cheap and easy to make, and would not carbon up.
Joel
Old Nov 13, 2014 | 10:27 PM
Just-Another-Dieselguy's Avatar
Yes. It would shut the engine off
Old Nov 16, 2014 | 05:49 PM
Rooster24v's Avatar
Or you could invest in a 07.5-14 holest HE351VG turbo, this has a variable vane in it and provides ehaust braking similar to engine braking. 07.5-14 Rams with 6.7 come with this turbo from the factory!
Mar 2, 2015 01:10 PM
Dec 27, 2014 03:00 AM
wolfnexus
Nov 4, 2014 10:04 PM
Oct 31, 2014 06:10 PM
Oct 30, 2014 08:10 AM
