IP Timing
Old Nov 12, 2014 | 09:57 PM
91 7three's Avatar
Default IP Timing
Can anyone give me like a step by step on how to advance the timing? I know the basics like which way to turn the pump, how far to turn it at a time, etc.. But can someone go into a little detail. Like where the nuts/bolts are to loosen the pump, where the timing mark is, small details like that. My timing seems a little retarded so id like to advance it a little this weekend. I cant really bring it to a shop because I dont have the money, and the truck isnt insured at the moment so I cant drive it there. Its my weekend play around truck so I figured id just do it myself. Thanks in advance
Old Nov 14, 2014 | 10:37 PM
Sycostang67's Avatar
There are 3 bolts holding the IP to the gear housing cover. There should be a line on the middle top of where the IP meets the cover. There should be a line on your IP as well. If there is no line on your IP then you need to make one to use as a reference as to how far you have turned the IP.
quiksilver1j
Jul 30, 2015 12:41 PM
Stox5225
22
May 14, 2015 05:17 PM
Derag2
Apr 2, 2015 07:57 PM
SMatyac
Nov 15, 2014 07:35 PM
jjbced
Oct 26, 2014 09:09 PM
