91.5 w250 3 questions
Old Nov 11, 2014 | 10:50 AM
95xtracab's Avatar
Default 91.5 w250 3 questions
hey fellas i just got my first 91.5 w250 4x4 cummins with an auto. I'll get straight to the questions thanks for your help in advance.
Does anyone know where i can buy the stock wheel rings and center caps can't seem to find anyone parting one out or in the junkyards, i thought about 2wd center caps but not sure how they'd look. thanks I'm in northern california.
I have a electrical problem. keep blowing my power window fuses, parking brake light stays on, and the famous no overdrive. i put a ecm out of a ram charger in yesterday and the wait to start light started working and speedometer started working and my tps started to get voltage. no overdrive though, i will check the overdrive solenoid in a couple minutes and report back.
any advice heres my number 808 4 two 8 7291. thanks in in the bay area of california
Old Nov 11, 2014 | 01:08 PM
mknittle's Avatar
If it is the dog dish hubcaps you are looking for watch the wrecking yards for 3/4and one ton vans. I was thinking if I could find four I could use a hole saw to cut the centers out of two to make fronts.
good luck hunting
Old Nov 11, 2014 | 01:58 PM
95xtracab's Avatar
i was thinking the same thing, probably what i will end up doing seems like all the pick n pulls they take the wheels and tires off before putting them in the yards!
Old Nov 11, 2014 | 10:47 PM
95xtracab's Avatar
well i wired up the toggle switch from my overdrive solenoid and it shifts perfect. what is the next step in the equation? when i pulled the overdrive solenoid plug just to check it out there was a little fluid on it? is that right?
Old Nov 12, 2014 | 05:54 PM
95xtracab's Avatar
also brake light is still on and windows keep blowing fuses, any help is appreciated
ofelas
Show And Tell
Aug 18, 2015 12:26 AM
Mar 20, 2015 08:20 AM
Jan 13, 2015 09:00 PM
Nov 28, 2014 09:50 PM
Nov 12, 2014 08:10 AM
