84 f250 lift question
Old Nov 1, 2014 | 07:00 AM
tumble72's Avatar
Default 84 f250 lift question
So I want to lift my 85 f250 6.9. It's a long box super cab. I want to put a 3 inch body lift and a 4 inch suspension. Should I use lift blocks or lift leaf springs?
Old Nov 1, 2014 | 04:09 PM
4x4manonbroke's Avatar
Block for price .. Springs if you would like a slightly better ride ..
Old Nov 1, 2014 | 04:11 PM
tumble72's Avatar
On a budget so block for now upgrade later
Old Nov 3, 2014 | 10:21 PM
buy new U-bolts .. dont skimp there .. and make sure you do the torque correct on them or they can/will break sddenly when your loaded .. I found out the hard way .. nearly a real bad accident ..
Old Nov 3, 2014 | 10:24 PM
tumble72's Avatar
Thanks I will gonna go get and put in this weekend
Old Nov 3, 2014 | 10:35 PM
Make sure your U-bolts are Grade 8 .. criss cross tighten them and use a torque wrench .. Dont do it with a impact gun . I know its easier .. you will be able to sleep @ night by doing it right ..
Old Nov 3, 2014 | 10:39 PM
tumble72's Avatar
I don't us impacts very often don't care for them I'm get them from super lift they come with the blocks and u bolts and new shocks
Old Nov 6, 2014 | 12:33 AM
Awesome
Old Nov 6, 2014 | 11:03 AM
91 7three's Avatar
good way is just to go blocks in back and springs in front because the front end takes most of the braking and theyve been known to flip out of the front. but if you run blocks in the front, torque them good and just dont go too tall with them.
Old Nov 10, 2014 | 09:06 PM
When I use blocks up front or rear . I typically lay a nice fat tack weld on them on all 4 corners ..
landon025
Sep 8, 2015 09:21 PM
PA 24valve
Aug 31, 2015 06:08 AM
Brushout
Audio Equipment/Electrical
Mar 18, 2015 10:54 PM
moneypitk5
Feb 12, 2015 11:01 AM
CJJD4640
9
Feb 9, 2015 07:22 AM
