Chevy/GMC Duramax 07.5 -10 LMM Discussion of Chevy and GMC Trucks with LMM Duramax Turbo Diesel Engines
Need some advice
Old Oct 29, 2014 | 11:21 AM
lifted07sierra's Avatar
Default Need some advice
Hi everyone ... To make a long story short I took off black plastic box underhood that says 6.6 turbo and capped it off with 2" rubber cap. Was planning on doing pcv reroute but before I could I got on the highway and 20 miles down the highway truck went into reduced power mode. Any help or advice would be greatly appreciated
Old Oct 29, 2014 | 04:15 PM
2500HeavyDuty's Avatar
check the wiring around that area, you could of bumped something, the res delete should eff with anything
Old Oct 29, 2014 | 04:45 PM
I'm headed to my house now so I'll check it out and see if that's what happened cause I didn't think it would effect anything. Also anyone got any quick and easy ways to make the whistle from the turbo louder besides straight down pipe and metal intake tube
Old Oct 30, 2014 | 01:22 AM
Just-Another-Dieselguy's Avatar
In a nutshell the best way to hear your turbo more is going to be a straight pipe and a good Air intake
Old Nov 6, 2014 | 08:24 AM
Motorops's Avatar
FormerVendor
Straight pipe the exhaust and put a cold air intake on the truck. At that point you are going to need tuning as well to help shut the codes off when you straight pipe the truck.
These three modifications will help efficiency and MPG as well as increasing throttle response and spool up
Chris-
brianj2077
Aug 4, 2015 09:06 PM
Spaky6.0mudder
Aug 3, 2015 08:54 PM
twm011
Feb 24, 2015 09:11 AM
Ryan1531
Feb 17, 2015 06:46 PM
jrsavoie
Feb 6, 2015 09:44 PM
