35-Inch Tires on 20-Inch Factory Wheels
Old Oct 26, 2014 | 08:09 AM
smokerattlenroll's Avatar
Default 35-Inch Tires on 20-Inch Factory Wheels
I'm trying to make a decision between 2 different tire sizes: 295/65R20 and 35x12.5x20. I want to use the factory 20-inch wheels on my 2015 3500 and do not want a lot of tire hanging outside of the wheel well.
I'd appreciate any front and rear-view photos you may have of a 2014/2015 Ram 2500/3500 with either 295/65R20 or 35x12.5x20 tires mounted on 20-inch factory rims.
Thanks.
Old Oct 28, 2014 | 04:31 AM
u2slow's Avatar
If you are keeping the same wheels, its pretty simple math how far a 12.5" wide tire will bulge, and from that, how it will locate in respect to the body.
Old Oct 29, 2014 | 01:04 AM
Just-Another-Dieselguy's Avatar
For the record 295's are not close to 12.50 wide. (295) is I'm mm.
Old Oct 31, 2014 | 11:10 AM
It certainly is simple math if you have a truck sitting in front of you. How many equations do I need for the present number of unknowns with which I am faced?
Old Oct 31, 2014 | 11:12 AM
Correct; that's the reason for the request.
Old Oct 31, 2014 | 02:04 PM
u2slow's Avatar
Haha... what's the stock tire and wheel size/width?
I have 295 wide rubber on 7-1/2" wide 6" backspace wheels on a 70" wide axle in my '93. Tires are basically flush with the relatively narrow 1stgen body. (rear; my front axle is setup different. 315 (12.5") wide tire would add ~1/2" to the outside.
I know its not the same truck, but your axles and wheel backspace will be very similar.
Attached Thumbnails 35-Inch Tires on 20-Inch Factory Wheels-20140701_215948_resized.jpg
Old Mar 30, 2017 | 05:17 AM
98springer's Avatar
Mine has 35X12.50X20's and they don't hang out at all. On my 2006 they are well inside the weelwells
Kooper
Dec 4, 2015 12:03 AM
Jsully
Aug 31, 2015 07:55 PM
Apr 30, 2015 08:10 AM
CumminsAtYa
Wanted To Buy (WTB) - Used
Mar 12, 2015 06:20 PM
ironforger
Nov 17, 2014 10:25 AM
