Stock Rim Size On 99 Dodge
Old May 6, 2008 | 10:03 PM
Uncle Bubba's Avatar
Default Stock Rim Size On 99 Dodge
Can anybody tell me what size wheels came on the 1999 single wheel 2500 4WD's. The steel wheels. I'm gettin my trailer ready for hay season and need to put some new rubber on it. It's gonna be sportin 6 stock Dodge wheels on it.
Old May 6, 2008 | 10:18 PM
slowtowpig's Avatar
16in
Old May 6, 2008 | 10:20 PM
Thanks, do you know how wide by any chance.
Old May 6, 2008 | 10:25 PM
slowtowpig's Avatar
i want to say 8... i will search it to make sure
Old May 6, 2008 | 10:29 PM
Hope you have better luck, I tried to find it.
Old May 6, 2008 | 10:30 PM
slowtowpig's Avatar
eBay Motors: DODGE RAM 2500 16" POLISHED TRUCK WHEEL RIM 1 u (item 160237611296 end time May-08-08 17:00:00 PDT)
99 dodge 8lug alloy wheels are 16x8
Old May 6, 2008 | 10:55 PM
They should be 16X6.5
From dodgeram.org:
1994-2002 2500 2WD/4WD Steel Wheels:
Lug Pattern - 8 on 6.5", 9/16" bolt
Rim Size - 16x6.5"
Offset - 4.75"
Max Tire Size - 245/75R16, 255/85R16
Dodge Ram Specifications
*** max tire size stated there isnt necessarily correct - Im running 285's on the chrome wheels with the same measurements ***
Old May 6, 2008 | 11:00 PM
In the description they show this wheel as a 16X6.5, never seen one like that though it must have some special optional wheel.
Thanks all. Now I just have to find as narrow as possible tire to fit on this rim in load range E and I'll be set.
Old May 6, 2008 | 11:03 PM
Uh, look at my post...
That ebay wheel is a forged aluminum wheel from a 2000+ and its 16X8"
Old May 6, 2008 | 11:14 PM
No fair addin to your post after mine. I just read through it real quick and saw the 8 lug on 6 1/2 and didn't take the time to read into just what he was talkin about there. Had to go back and check it out again.
