99-03 7.3L Performance Discussion of 99-03 7.3 Liter Ford Powerstroke Turbo Diesels Related To Performance And Longevity
7.3 injectors rebuild
Old Oct 7, 2014 | 09:37 PM
drwaters1981's Avatar
Default 7.3 injectors rebuild
I got a set of injectors for my truck and I'm rebuilding them but I don't know the upper body torqued to the lower body need to be if any body knows anything about this please share info reason I'm posting this is because I'vebroke 3 nozzles by over tighting the injector but I have replacement nozzles on the way thanks for your time
Old Oct 8, 2014 | 08:55 AM
joebob3093's Avatar
Moderator
Send them to someone who knows what they are doing, you will thank me later
Old Oct 8, 2014 | 10:22 AM
I wanted to rebuild them my self so I need the torque spec I want to build them right
Old Oct 8, 2014 | 09:01 PM
joebob3093's Avatar
Moderator
You will have to send them to someone eventually so do yourself a favor and have them built right
Old Oct 8, 2014 | 11:58 PM
I only paid 150 for all 8 injectors and I wanted to see if I could rebuild them anybody can do just about anything if they put there mind to it .so if even if I do mess up one 1 or even all the injectors this will be something that I can same I have done and about sending them off to get rebuild I guess u say I just don't have that cash flow .the only thing i know is I've looked everywhere for specs on those injectors and i can't find any and all i need to know is how much torque does the upper and the lower body need for the o-ring to seal it and so i don't break anymore nozzles.
Old Oct 9, 2014 | 12:42 AM
joebob3093's Avatar
Moderator
Couldn't tell you. No one but shops build their own injectors. So your on your own to find that info. I know from my experience I will never try to build my own and I will always send them to a trusted shop to have injectors built. But even if you find the info you will have to send them to someone to be flow tested.
Old Jan 21, 2016 | 07:44 PM
Kooper's Avatar
Did you ever find out what the spec was? finish rebuilding them? they work? I know this is an old post but I am very curious to know, thanks.
Old Jan 22, 2016 | 09:49 AM
joebob3093's Avatar
Moderator
no one should ever try rebuild them yourself unless you like a pickup that doesn't run correctly and have money for new injectors and or an engine.
Old Jan 22, 2016 | 10:41 AM
Kooper's Avatar
I don't see what would be the issue.
From study the 7.3l injectors are not complex, I've built far more complicated items for my work.
Old Jan 22, 2016 | 05:26 PM
joebob3093's Avatar
Moderator
do you have a flow bench so you can flow test them?
