Chevy/GMC Duramax 07.5 -10 LMM Discussion of Chevy and GMC Trucks with LMM Duramax Turbo Diesel Engines
2008 lmm low rail pressure hard shifts
Old Sep 30, 2014 | 12:58 PM
growland415's Avatar
Default 2008 lmm low rail pressure hard shifts
hey guys im helping my buddy on his 08 its tuned by duramax tuners has a 150hp tune i plugged my cts into it and it says at WOT the truck wants 21,000 psi and the actual FRP is only 2235psi and the truck shifts hard????? truck has brand new fuel filter and 138,000 miles i was maybe thinking cp3 is out
Old Oct 9, 2014 | 08:56 AM
Motorops's Avatar
FormerVendor
Does this truck have a Lift pump? and it's only at Wide open Throttle?
How is the truck at idle? smooth or is it lopey?
Old Oct 14, 2014 | 11:24 AM
no lift pump and yes only WOT idle is smooth
Old Oct 14, 2014 | 02:17 PM
Motorops's Avatar
FormerVendor
Without being by the truck, its seems like it is not holding rail pressure, i would check the Cp3, it isn't holding pressure for the TCM to recognize when to ****
Old Oct 20, 2014 | 10:20 AM
Motorops's Avatar
FormerVendor
Spell Check** Shift.
Old Oct 22, 2014 | 01:56 PM
2004LB7's Avatar
double check the 2235 PSI. seems real low, likely won't run or will stall at that PSI. maybe a bad pressure sensor
robbyS
Apr 16, 2015 02:22 PM
jhprice
Mar 29, 2015 09:36 PM
Ruddedawg5.9
Mar 1, 2015 09:16 PM
powerstroke4178
Nov 27, 2014 02:35 PM
Jeremy Babb
Chevy/GMC Duramax 01-04 LB7
13
Oct 1, 2014 06:27 AM
