Injectors help!
Old Sep 29, 2014 | 10:36 AM
scottxmorris's Avatar
Default Injectors help!
Ive been looking at some quick ways to gain some good hp on an 2001 6 speed 24-valve with 270k miles and injectors seem to be the way to go...will i have to do any major mods to the injection pump or head studs if im going for 100 hp injectors? I want to gain power the right way and i know its gonna cost money. Thanks
Old Sep 29, 2014 | 10:41 AM
gh0stman's Avatar
You shouldnt have any issues going with 100hp injectors, but that is assuming you havent made any other mods. You also want to get gauges to monitor exhaust temps, fuel pressure, and boost pressure.
Old Sep 29, 2014 | 10:49 AM
Ok everything on the truck is stock except the silcener ring is removed but that really doesent affect anything but how is the fuel pressure gauge installed? And is it really essential? Im having the gauges installed before the injectors
Old Sep 29, 2014 | 11:00 AM
gh0stman's Avatar
Fuel pressure is vital, without the ability to monitor you run the risk of burning out the VP. I have a FASS lift pump supplying my VP. With 1/2 fuel lines I have a XDP quick connect fitting that my fuel pressure gauge it hooked into. I usually run 19 at idle and 18 psi driving down the road. in addition to changing injectors I would also upgrade the lift pump for a piece of mind.
Old Sep 29, 2014 | 11:04 AM
gh0stman's Avatar
A fuel pressure gauge can be installed with a banjo bolt connected to the side of the VP and have a gauge ran inside the cab. Not a difficult install.
Old Sep 29, 2014 | 11:17 AM
Ok for 100hp injectors what kind/style lift pump do i need? Do the fuel lines need to be replaced with a larger size? Or will stick still carry the fuel needed?
Old Sep 29, 2014 | 11:20 AM
gh0stman's Avatar
I would stay away from airdog, I went with the setup in my sig. The kit comes with 1/2 inch fuel lines and all the connections you need to make it run. The 95 GPH according to FASS will support up to 600hp. It takes about 2 hours to install worst part is disconnecting the old fuel line from the tank.
Old Sep 29, 2014 | 11:31 AM
Will the stock lines carry the fuel or are they to small?
Old Sep 29, 2014 | 12:54 PM
gh0stman's Avatar
Search google and Youtube. They will be able to better inform you of these products.
Old Sep 30, 2014 | 04:26 PM
jigabop's Avatar
stock feed line can still carry the fuel.
stock return line never gets removed even with aftermarket 1/2" fuel lines you still retain the stock return line as the vp44 still needs to return fuel for cooling purposes.
I run 1/2" draw straw, fuel line, and air-separation/pressure regulation return line on my rig.
and a mechanical fuel pressure gauge on the dash...
my lift pump is a 150GPH air/fuel & water/fuel separation + fuel filtration system comparable to the fass titanium system.
you don't need all that fancy stuff, but you do need at least a 95GPH lift pump to run higher than stock power.
