1995 GMC 3500hd 6.5 turbo
Old Sep 28, 2014 | 01:52 PM
gremlin75's Avatar
Default 1995 GMC 3500hd 6.5 turbo
Having issues... no power. Codes set for a few years. Pdm cooler. Had a service body with a crane and hyd. air comp. Any help?
Old Sep 29, 2014 | 08:57 AM
racer55's Avatar
care to post the trouble codes associated with the truck?
we need a lot more info that what you have provided to give any decent help.
Old Sep 29, 2014 | 04:20 PM
gremlin75's Avatar
Default codes
Code. 62 is all I'm getting now. Had ecm 2 blow fuses. Fsd cooler from Green bay diesel.
Old Sep 29, 2014 | 04:23 PM
gremlin75's Avatar
Default codes
Code. 62 is all I'm getting now. Had ecm 2 blow fuses. Fsd cooler from Green bay diesel. Misses like air in fuel. Like the mechanical pumps better. Like my 6.9, & DT 466, v8 deutz.
Old Sep 29, 2014 | 06:24 PM
racer55's Avatar
DTC 62 - Turbo Boost Sensor Circuit Low
A common miss cause is from the optical sensor noise filter-remove it and get some ferrite core from radio shack so that you have a piece on each OS wire when the harness is plugged directly in without the electronic noise filter.
Old Sep 29, 2014 | 08:24 PM
gremlin75's Avatar
I took it out and went from 4 codes to one. 62 but no 12. 3 of the wires had open copper.
Old Sep 30, 2014 | 08:45 AM
racer55's Avatar
You may need a new boost sensor but check the wiring?
Did removing the OS noise filter help with the miss?
Old Oct 1, 2014 | 08:05 AM
gremlin75's Avatar
When noise filter was removed works good but still have a 62 code Intermittent. And ecm b blows like a short. Any idea where it runs?
Old Oct 1, 2014 | 08:56 AM
racer55's Avatar
Have you checked the boost sensor that is screwed down to the upper intake and it's wiring?
ECM B fuse powers the ECM,the LP relay and LP near as I can tell.
Old Oct 1, 2014 | 09:15 AM
gremlin75's Avatar
Lp?
