6.2 coolant mystery
Old Sep 28, 2014 | 12:37 PM
jdcarter's Avatar
Default 6.2 coolant mystery
I have a recently rebuilt 6.2 with banks sidewinder kit. I have replaced the radiator tstat water pump and all hoses and I even by passed the heater core to eliminate it. When my truck gets to temp and flows into the over flow tank it never returns to the radiator. I have no other issues with motor. No smoke white or black no water in the oil no sweet smells. Except for the diesel fuel...haha I am completely lost here
Old Sep 28, 2014 | 03:44 PM
racer55's Avatar
The overflow tank accepts the expanding coolant after being heated.
If the rad cap and tank are working properly-the excess coolant should be sucked back into the rad when everything cools down-there can be no leaks in the bottle and the cap must let air back in the tank to take up the space from the coolant going back.
In the old days there were only overflow to the ground because the system does not need the extra coolant-the tanks and double acting rad caps were made to keep the streets cleaner and not poison everything.
Old Sep 28, 2014 | 10:05 PM
jdcarter's Avatar
I found the issue after just running it like a stolen go kart in the driveway when I rev it and build a good bit of pressure the filler neck started to squirting from under the cap so u guess I got a bad Mexico radiator...
duramax on fire
Chevy/GMC Duramax 01-04 LB7
11
Aug 14, 2017 09:51 PM
caissiel
Sep 24, 2015 05:37 PM
Rayrock4
Aug 30, 2015 09:45 PM
97f-250
Nov 23, 2014 08:08 PM
gmcmanis
Nov 9, 2014 04:49 PM
