been gone a while got a couple questions
Old Sep 7, 2014 | 08:03 AM
willis964x4's Avatar
Default been gone a while got a couple questions
Ok first off its good to be back been gone a while now for tge questions on my 97 k3500 6.5 every time I start the truck I get a puff of white smoke and it surges (rpms go up and down) until it gets to operating temperature after that it runs like a dream what would cause the surge? Replaced lp new injectors and the second question is last winter I put it in 4hi went to back out of my drive and heard a pop come from the front end and 4x4 hasn't engaged since but nothing is broken ive checked the cv axles and all idk what it would cause that? Could the actuator be bad? Would that make the pop noise? Any help is appreciated
Old Sep 7, 2014 | 08:29 AM
racer55's Avatar
Check for trouble codes?
Air in the fuel could be causing the surge?
replace the IP fuel return hose with clear diesel rated fuel line and watch for bubbles when it's idling.
Timing problem?
Bad CPS?
Very likely that the frt axle actuator has failed-they were troublesome.
Old Sep 7, 2014 | 08:31 AM
No codes had it scanned several times
Old Sep 7, 2014 | 04:40 PM
Mayhem's Avatar
X2 on the actuator they are the weak link just replaced mine,check the 4X4 fuse if blown the actuator is bad.
Old Sep 7, 2014 | 05:32 PM
Thats what im hoping it is but tge only thing that has me confused is the pop I heard I ddidn't know if the actuator would make that sound
Mar 20, 2015 08:20 AM
Jan 13, 2015 09:00 PM
Nov 28, 2014 09:50 PM
Nov 12, 2014 08:10 AM
Hardcorefx4
Oct 6, 2014 07:47 PM
