rpm's go crazy, wont idle down
Old Sep 1, 2014 | 10:40 AM
chuckie's Avatar
Default rpm's go crazy, wont idle down
Have 1996 Chevy 6.5 Turbo (VIN F) Engine Warm up press accelerator RPM go crazy Want idle down. Change Fuel petal (AAP) Replace Vac. pump. Have no code . Is it the Turdo?
Old Sep 2, 2014 | 05:39 AM
Mayhem's Avatar
Swap the PMD out with a known good one.
Old Sep 2, 2014 | 10:57 AM
racer55's Avatar
Could be PMD or IP?
Change to a known good remote PMD with heatsink,resistor and extension harness first since it's the cheapest test and everyone who owns an electronic IP should carry a spare PMD anyways so even if the IP is to blame the PMD money spent is not a waste.
Old Sep 2, 2014 | 01:26 PM
chuckie's Avatar
Will do THANKS Will let you you know.
Old Sep 9, 2014 | 11:23 AM
chuckie's Avatar
I change the IP & PMD It fix IT. You are the best. One more thing Timing I Pump is it POSSIBLE?
Old Sep 9, 2014 | 02:41 PM
racer55's Avatar
it requires a scan tool that will at least display the TDCO value.
TDCO=timing top dead center offset(timing)
stock spec is:-0.25 to -0.75
performance spec is:-1.50 to -1.94
the negative(-) is important to see because it denotes advanced timing-no (-) beside the value means late timing.
If your scan tool only displays the value you will need to google:KOKO relearn and use that for the ECM to learn the location of the IP.
A snap on MT 2500 will display the TDCO value but you should enter the model year as 2000 no matter what year the truck is from 96 on.
If you have a scan tool that can initiate the TDCO relearn on it's own then follow it's procedure.
Carcode and AutoEnginuity are both laptop based scan tools that can initiate the TDCO relearn as well as GM's TechII.
2500ctd
Jun 23, 2016 01:22 AM
Daylon
Aug 23, 2015 11:01 AM
Mc Merc
Dec 16, 2014 06:59 AM
cdetterer
15
Dec 8, 2014 08:46 PM
JMC23
5.9L 24V Performance
Oct 28, 2014 11:03 PM
