Can I use my 92 Cummins tranny when I swap to Chevy?
Old Sep 1, 2014 | 10:29 PM
jskelt's Avatar
Default Can I use my 92 Cummins tranny when I swap to Chevy?
I'm doing a Cummins swap to an 85 Chevy 3x3. I believe my 92 Cummins has the 46RH automatic tranny in it. My question is: has anyone done this swap and used the 46RH tranny or does anyone know if it can be done? I'll change over to an NV4500 or NV5600 eventually, but just want to get the swap done ASAP. Thanks for your input!
Old Sep 1, 2014 | 10:47 PM
cumminsblazer's Avatar
Yes you can run the 46rh is it 4x4 ? Doesnt matter for the swap just wondering if its 4x4 and are you gonna do a build thread is I want the link to watch I can give many pointers in the build im very happy with my swap
Old Sep 1, 2014 | 11:02 PM
jskelt's Avatar
Thanks! The 46RH is 2wd. I haven't decided if I'll post a build thread yet.
Old Sep 2, 2014 | 12:18 AM
Is the 3+3 gonna be 2x4
Old Sep 2, 2014 | 03:12 PM
dezeldoc's Avatar
It is not a problem but you will need to either put a pressure switch or toggle switch in to activate the o/d. you will not need any of the computer stuff either as the motor and trans are pretty much stand alone, but you will need to wire a mopar electronic voltage regulator into it to make it charge, pretty easy though. if you are planning to run cruise control then you will need the tps and crank trigger also.
Old Sep 4, 2014 | 06:00 PM
Plus on the tranny note if you were to run a chevy tranny it would have to be a th 400 so you wont have over drive th350 not strong enough 700r4 not strong enough I dont care how bult they are.
Old Apr 14, 2015 | 10:12 PM
Dickey's Avatar
Default Lots of chevy cummins conversion????
Ok not sure where this should be posted so please be patient,I have a 1991 dodge 250 cummins with 518a 4x4 that I'm using as a donor for my 2003 chevy 3500 duramax......I bought it with no motor or tranny,I would like to use everything I can off of donar but I can't figure out for sure which transfer will work with my tranny as I've read a million conflicting inputs,I'm looking at mounts from auto world unless someone can lead me to a cheaper solution.im going to make this happen come hell or high water ,I just want to be on the right track before I pull front clip.any and all help would be GREATLY appreciated.!!!!!
Old Apr 14, 2015 | 11:57 PM
novapat's Avatar
I agree with the 700r4 but I will take that bet on the th350!!! I have done many with great success!
btw hows your truck going? did you ever make it to the track?
DieselDan370
Diesel Engine Conversions
Aug 23, 2016 02:24 PM
STDiesel59
Jul 11, 2015 10:09 AM
DieselDan370
Jun 8, 2015 06:21 PM
Big Sal
Apr 19, 2015 03:59 PM
ReckONE
Feb 25, 2015 09:41 AM
