Oil cooler
There's oil in the coolant so I'm assuming it's the oil cooler. Does anyone have any idea in what needs to be fixed? What seals, O-Rings, gaskets need replacing to stop this leak? And also I need to know where to get these seals. Thanks.
Actually that's the other way around. You can get the gaskets anywhere(in stock at my O'reilly's), it's the o-rings that are a pain to find. Rockauto.com sells a complete kit for around $30 I think. My brother in law just ordered a kit the other day. It should arrive tomorrow night. He is using my spare 7.3 while he gets his rebuilt but the cooler needed rebuilt first.
I believe the gaskets are Fel pro's, ES72519. Interestingly though I looked on line and they list a complete set with o-rings now as well. It's a Dorman part though, 904-223. I may be wrong about them being a stocking item. I will have to double check next time I am at work. The website says they aren't but the website has been wrong about a lot of things.
I was wrong about them being stocked, but they are available overnight at no extra charge as they are stocked in the distribution center. The complete set from dorman may take a few days though as I have no idea where they are coming from.
Yes, that is the part number for the gaskets only, it's a Fel-Pro brand.
This is weird, I was looking at it again and got another part number. I am also showing ES70689 as the oil cooler gaskets as well and they do show as a stocking item at the overland/latah store. It is also Fel-Pro. When I look up both part numbers, they list the same applications.
Bighouse
Apr 9, 2015 06:51 PM
