C6500 Cat wont rev out!
Old Aug 10, 2014 | 09:42 PM
zeause's Avatar
Default C6500 Cat wont rev out!
I have a 2000 model c6500 I just bought. It has the 3126 Cat in it and a 5 speed spicer I believe. It's been at mhc getting checked over and they come to the conclusion that the speedometer not working is the reason it wont go past 17-1800 rpm in any gear. Has anyone else ever had a problem like this? It isn't throwing a cel until it hits the cut off and then it just flashes and goes away. It is almost like hitting a governor. Runs great and starts to build boost until it hits also. Any help is greatly appreciated. I have searched and couldn't find anyone else having the same issue. Thanks!
Old Aug 18, 2014 | 09:08 AM
cummins_guy's Avatar
Do you get any codes?, if it flashes, it should store a code.
Just from what you have described, it sounds to be normal, if you are reaching 1800 rpms that isa little low, what series do you have, (b, e, etc)
More info would help
Is the cluster reading correctly?
When is the last time it had an oil change, is your oil level on the stick correct (showing full)
These are run off of oil pressure.
brianj2077
Aug 24, 2015 04:04 PM
Jct
Jun 23, 2015 07:52 PM
muddyold7.3
Marine Diesels
Feb 4, 2015 05:23 PM
RLLBZ
Chevy/GMC Duramax 01-04 LB7
Jan 27, 2015 03:05 PM
Allen@XDP
XDP Diesel Power
Nov 25, 2014 04:16 PM
