gas too diesel conversion
im looking at buying a bronco and later on converting it too diesel what motor would you suggest im not too concerned about doing metal fab im fine with doing some modifications as long as i know the motor will fit?
i dont want too do a 4BT Cummins
cummins or powerstroke only
A cummins swap would require some metal fab to work. A power stroke swap will mostly just require parts swapping as you would need the drivetrain, motor mount pedestals, core support, entire gauge cluster, wiring and the gas pedal(drive by wire) to swap into the bronco.
Jet A Fuel
Aug 3, 2015 10:45 AM
Oct 31, 2014 06:10 PM
