Need advice on twins
Old Aug 6, 2014 | 09:17 PM
oldblu92's Avatar
Default Need advice on twins
I have a 66/74/14 single right now and want to add another turbo. I have an aurora 5000 sitting around would that be a good one to put on?? If not ill get a s480. Any input is great thanks
Old Aug 7, 2014 | 12:28 AM
RAW's Avatar
RAW
If I remember correctly, a A5000 is a 71mm. Should do just fine with your set up.
Old Aug 7, 2014 | 10:22 AM
oldblu92's Avatar
I think that's what I'll try. I was just wondering if they were to close in size? What mm is a 480 do you know?
Old Aug 7, 2014 | 12:11 PM
RAW's Avatar
RAW
80mm. The 4 in the 480 is the frame/body size, and the 80 is mm size of compressor inlet.
Old Aug 7, 2014 | 04:30 PM
oldblu92's Avatar
Ha duh ok thanks for the input man
Old Sep 15, 2014 | 11:37 AM
jigabop's Avatar
that is going to be one smokey and laggy setup...
might want a shot of N20 just to get it going and hopefully stay on top of the boost once you do get them lit because if you fall below that it'll fall on its face and just pump soot with no power.
adding a second turbo to your current one is going to INCREASE the lag of your current turbo because it now has to spool a second larger turbo with it.
brianj2077
Aug 4, 2015 09:06 PM
Spaky6.0mudder
Aug 3, 2015 08:54 PM
leakin 12 valve
Off Roading
Aug 1, 2015 06:21 PM
Chris Pittman
5.9L 12V Performance
Mar 21, 2015 05:00 PM
twm011
Feb 24, 2015 09:11 AM
