turbo thoughts?
Old Aug 4, 2014 | 09:21 PM
kyle davis's Avatar
Default turbo thoughts?
i have a 92 auto 2wd that i recently resealed the i.p. and bumped the timing a bit,3200spring,adjusted power screw a bit,and just got a set of 5x.016 injectors put in. I have access to the stock h1 turbo,a hx35 from a 2000,and a ht60 that needs rebuilt. question is whats the best turbo(turbos) setup for this fuel range, i was thinking maybe even an old school setup of triples?but give me ideas please
Old Aug 10, 2014 | 09:12 PM
kyle davis's Avatar
nobody has thought or ideas on this? what an ideal setup for this even?
Old Aug 11, 2014 | 06:30 PM
turbo2332's Avatar
nothing mentioned will complement the very large injectors you just put in your truck. i would urge you to an s300 with a 71mm turbine wheel. a stock turbo will melt down with this much fuel and your little engine will never ever spin an ht60.
Old Aug 12, 2014 | 09:51 PM
kyle davis's Avatar
ok thank you. im also looking at building a small set of twins and even with these injectors its not that smoky
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
n2brk
Feb 21, 2015 09:05 AM
tumble72
8
Nov 27, 2014 10:31 PM
GreenDieselF
Oct 20, 2014 02:05 PM
