06 cummins
Old Jul 28, 2014 | 03:10 PM
Nate88's Avatar
Default 06 cummins
My 06 cummins died while jumping anothet truck off an now will spin over but wont fire up an the fuel control actuator is clicking has any body else seen this
Old Jul 28, 2014 | 03:47 PM
Bigg Redd's Avatar
Any codes? Engine light on?
Old Jul 28, 2014 | 03:57 PM
Nate88's Avatar
Check engine light flashes at the same speed the fca clicks
Old Jul 28, 2014 | 04:20 PM
Bigg Redd's Avatar
Try this, its simple and only costs you a bit of time. Clean all of your ground connections, to the block and the frame and engine bay. There are several. Also clean your battery cables connctions to the batteries ( disconnect all terminals to the batteries. after cleaning them, connect the positives first, then the negatives. This should reset the ECM and clear any codes. If it works, ya found the issue. The grounds should be cleaned every once-in-a-while anyway. It worked for me..........hope it works for you.
Old Jul 28, 2014 | 04:28 PM
Nate88's Avatar
Thanks i disconected both batteries yesterday for about an hour an still same thing but i will try cleaning the grounds
Shun70
Diesel Engine Conversions
Jun 1, 2026 05:02 AM
Dec 18, 2014 03:25 AM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
