6.2 wont start, any ideas?
Old Jul 16, 2014 | 11:48 PM
whiteking21's Avatar
Default 6.2 wont start, any ideas?
Just purchased a 83 k20 6.2 was running great, starting but then I think I ran out of gas and it wont start now. Thought it was the starter at first because it wouldn't even crank. The connection was loose, solved that problem. Then I put 5 gallons of diesel in the tank and removed the fuel filter to see if it was dry but it was full. So I don't think I ran out of gas but now when I try to start it won't turn over it just keeps cranking. If there is fuel in the filter I believe there would be fuel going into the injectors? Any ideas would be great. I purchased a new starter thinking it was the original problem but I am not so sure. Appreciate any of your help
Old Jul 17, 2014 | 01:34 PM
racer55's Avatar
You likely have air in the high pressure side of the system that needs to be bled out.
Air can compress so the injectors won't open.
Find an easy to get to injector and crack the nut on the fuel line loose and then try starting again.
Crank for no more than 15 seconds without a 1 minute starter cool down period.
Within 3 such starting attempts it should be running and then you can tighten the fuel line nut back up.
beware of moving parts and don't get caught in anything.
The rest of the injectors should self bleed once running and you should be good to go once it evens out.
Old Jul 17, 2014 | 09:05 PM
Ok. Attempted it with one, saw fuel come out and re tightened and it did not start.. Got rained out with heavy rain. Hoping to try it again tomorrow. Could there be that much air in the system it will take a while? Also should I be warming the glow plugs prior to each start? Appreciate your help!! really do.
Old Jul 18, 2014 | 01:55 PM
racer55's Avatar
You don't tighten the injector line until after the engine is running.
Yes cycle the glow plugs before every start.
Cavnar
Sep 9, 2015 07:18 PM
drice3050
Apr 26, 2015 09:06 AM
IGOU
Mar 8, 2015 04:25 PM
ronstop
Feb 26, 2015 09:48 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
