Engine feels like brake on while driving.
Old Jul 7, 2014 | 10:04 AM
treetalkn's Avatar
Default Engine feels like brake on while driving.
I am new to the forum as well as a newbie to diesel pickups. I have a 2001 2500HD 4x4 CrewCab with the 6.6L Duramax. I have noticed that while I am driving the rig there seems to be a feeling that the brakes were depressed and slowed the truck then it stops and it will do this all the time driving. If I set cruise control than it does great with no feeling of engine slowing and letting off.
I have searched the forums but cant seem to find anything.
2001 GMC 2500HD 4x4 CC 6.6L 250K miles. No modifications that I am aware of
Old Jul 7, 2014 | 05:28 PM
4x4manonbroke's Avatar
Any smoke ? trans fluid levels ? any CEL ? or codes ?
Old Jul 8, 2014 | 10:30 AM
treetalkn's Avatar
No smoke, fluid levels are good, no codes or check engine light. Changed the oil and fuel filter.
Old Jul 8, 2014 | 05:34 PM
Need to get in and scan it ... get the Fuel pressures... sounds like a starvation issue possibly ...
Old Jul 10, 2014 | 02:08 PM
treetalkn's Avatar
Can I get a scanner or do I need to take to diesel repair shop?
Old Jul 10, 2014 | 08:52 PM
detroitdiesel idi's Avatar
Tech two or autoengenuity
Old Jul 10, 2014 | 10:29 PM
K1SSRSS's Avatar
Air Filter, had this happen to me recently with the pickup I just bought. Changed the air filter and it mostly went away, I need to change my fuel filter and see if it completely goes away.
Old Jul 12, 2014 | 10:59 AM
A shop or EFI live will be able to scan it as well from my understanding ...
And by all manes look over the intake as well .. also .. might look into getting exhause checked for flow as well ..... if the Catalist is plugged it can Back pressure, strangling the engine
Old Jul 12, 2014 | 11:53 AM
2004LB7's Avatar
I believe that year did not come with a CAT. but your thinking of excessive back pressure causing the engine to have to work harder is correct.
i would check fuel pressure, fuel filter, air filter and MAF as a starting point
Old Jul 13, 2014 | 03:40 PM
Plugged muffler of baffels that have come apart inside ..
burndiesel
10
Feb 7, 2023 01:15 AM
Turbo67
Jul 25, 2015 02:26 PM
Rcracer78
Audio Equipment/Electrical
Apr 20, 2015 12:49 AM
metal_miner
Diesel Engine Conversions
Dec 23, 2014 11:40 PM
yams
Nov 29, 2014 09:25 PM
