Chevy/GMC Duramax 07.5 -10 LMM Discussion of Chevy and GMC Trucks with LMM Duramax Turbo Diesel Engines
Duramax LMM
Old May 1, 2008 | 12:23 PM
DB Admin's Avatar
Banned
Default Duramax LMM
The LMM specifications are nearly identical to the LBZ engine. It is a 6.6 L turbocharged engine and was introduced in 2006 for the 2007.5 model year. Its output has seen a slight increase of 5 hp (4 kW) and 10 lb·ft (14 N·m) of torque over the LBZ. This makes it 365 hp (272 kW) at 3200 rpm and 660 ft (201 m)·ft·lbf of torque at 1600 rpm. It's mated to an Allison 1000 6-speed transmission.
The LMM Duramax 6.6L V-8 has new equipment to help it meet the US EPA mandated 2007 emission standards. The new standard requires a 90-percent reduction in particulate matter (PM), compared with the previous standard, implemented in 2004, and a 50-percent reduction in oxides of nitrogen (NOx). The use of reformulated, ultra-low sulfur diesel fuel, which went on sale nationwide in the fall of 2006, is required to meet the new emissions standard and prevent damage to the emissions equipment.
Specifications
  • Engine Description: LMM
  • Displacement: 6.6L / 403 in³
  • Bore x Stroke: 4.06 in (103 mm) x 3.90 in (99 mm)
  • Block / Head: Cast gray iron / Cast aluminum
  • Aspiration: Turbocharged & Intercooled
  • Valvetrain: OHV 4-V
  • Compression: 16.8:1
  • Injection: Direct; Bosch High Pressure Common Rail with CP3.3 Injection Pump
  • Power / Torque: 365 hp (272 kW) @ 3,200 rpm / 660 lb·ft (895 N·m) @ 1,600 rpm
To meet the new emissions regulation in the US, the LMM Duramax 6.6 L V-8 engine features:
  • Additional combustion control, including an even more efficient variable-geometry turbocharging system, cooled (enhanced) exhaust gas recirculation (EGR) and closed crankcase ventilation to reduce nitrogen oxides (NOx)
  • Additional exhaust control, including oxidizing catalyst and new diesel particulate filter (DPF) to reduce soot and particulate matter
  • Increased-capacity cooling system
  • New engine control software
  • Use of low-ash engine oil (CJ-4)
The following trucks have or are due to have the LMM engine:
  • Chevrolet Silverado HD
  • GMC Sierra HD
  • Chevrolet Kodiak
  • GMC Topkick
  • Chevrolet Express/GMC Savanah
Old May 2, 2008 | 12:50 AM
cj ford's Avatar
is that hp and torque at the crank or at the wheels???
Old May 2, 2008 | 12:54 AM
TCU Fan's Avatar
Aaron
Crank.
Old May 2, 2008 | 12:57 AM
2500HeavyDuty's Avatar
crank fo sho
jt19
Aug 20, 2015 12:18 AM
speedracer565
May 24, 2015 09:04 PM
Renowest48
Dec 14, 2014 08:36 PM
duramaxtuner
Dec 10, 2014 01:24 PM
