Chevrolet Tahoe 6,5 TD 1996
Old Jun 27, 2014 | 02:38 PM
Peter P's Avatar
Default Chevrolet Tahoe 6,5 TD 1996
Hello. I am Peter from Slovakia. I bought a Tahoe with 6,5 Diesel and i have a problem. Sometimes when i drive the engine shut off. I change the PMD/FSD and i relocated to the front bumper - it is a Stanadyne, grey colour. And i changed the fuel shut-off solenoid. And the engine sometimes shut off, but i can start the engine immediately.
Please, help me.
Thanks
Old Jun 27, 2014 | 05:44 PM
cviola2005's Avatar
Have you used a scanner to read the computer codes? If no codes are read, then check the connections to the PMD/FSD, and check all grounds. There is one on the rear of the passenger side cylinder head.
Old Jun 28, 2014 | 12:15 AM
detroitdiesel idi's Avatar
I had a similar experience last year ended up bein ops and lift pump
Old Jul 5, 2014 | 06:19 AM
racer55's Avatar
Quite likely the problem is the ignition switch.
Pay attention next time it stalls and note if the instrument cluster dies at the same time as the stall,but the radio and blower motor continue to run as normal-if so the ignition switch is the culprit?
Pretty common issue.
Old Jul 7, 2014 | 09:14 AM
jrsavoie's Avatar
Could also be an air in fuel issue
Old Jul 7, 2014 | 03:55 PM
turbo2332's Avatar
if it was air it would take forever to re start. my guess is an injection pump if you have already replaced the PMD. 6.5's are such a pain the ds pumps nearly bankrubt GM back in the day. notorious for intermittant problems.
May 8, 2015 11:10 AM
Feb 12, 2015 03:00 AM
Nov 20, 2014 03:30 PM
Nov 5, 2014 05:30 PM
Oct 3, 2014 11:30 AM
