fuel ideas
Old Jun 23, 2014 | 09:33 PM
LostSoul71's Avatar
Default fuel ideas
I have been speaking to a buddy that has a frame mount electric fuel pump off of a powerstroke that he had suggested I use to create an electric system with external mounted filters and water separator. I am reading mixed about these pumps however. He tells me they put out about 70psi and I am concerned that would be too much pressure even with the adjustable OFV. I would think that with the reliability and more constant flow as opposed to the pulsing of the cam driven LP that this is a good option if the pressure is not too much. Any thoughts?
Old Jun 24, 2014 | 04:02 AM
turbo2332's Avatar
a powerstroke needs 50-55psi. if it is an air dog or fass you should be able to turn the pressure down to an acceptable level. i run in the 35-40psi range. i wouldnt want to run much higher for extended periods.
Old Jun 24, 2014 | 10:05 AM
4x4manonbroke's Avatar
Yeah that kinda pressure would not do your IP much favors ..
Old Jun 24, 2014 | 11:45 AM
NadirPoint's Avatar
I don't understand why people go away from the stock 2nd Gen lift pump.
Old Jun 24, 2014 | 12:10 PM
LostSoul71's Avatar
Okay thanks that means I would need a regulator of some kind
Old Jun 24, 2014 | 12:11 PM
LostSoul71's Avatar
I have not gone away. I even have a spare. I am just looking at options at this point.
Old Jun 24, 2014 | 03:22 PM
turbo2332's Avatar
because some of us need the volume of an electric pump. but from stock to 350ish hp applications it is silly to do away with the stocker. and you may not need a regulator. install a mechanical gauge on the top fort of the air dog and check to see what the pressure is. turn the jam nut out and see how low you can get the supply pressure to fall to.. if it is to high then you will need a regulator.
Old Jun 24, 2014 | 03:30 PM
LostSoul71's Avatar
I don't have access to an airdog just a Ford Powerstroke pump.
Old Jun 24, 2014 | 05:54 PM
turbo2332's Avatar
an OE 6.0 liter pump? i guess later model 7.3L had electrics too. anyway in that case yes, you will need an regulator
i personally wouldnt fool with it however if the stock lift pump is working properly, your after volume not necessarily pressure. more headace than its worth.
Old Jun 24, 2014 | 09:38 PM
LostSoul71's Avatar
Thanks I was looking for input either way.
Dbleo351
Nov 20, 2016 09:34 AM
Cavnar
Sep 9, 2015 07:18 PM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
