1992 starting problems
Old Jun 21, 2014 | 07:41 PM
boss4457's Avatar
Default 1992 starting problems
1992 6.5 diesel wont start when i go to try to start it you hear a humming sound. so i went to try it again it started right up now its doing the same thing again.???
i have checked the batterys
its not locked up
Old Jun 21, 2014 | 08:45 PM
burnhedge's Avatar
Does it crank over or just dead?
Old Jun 22, 2014 | 12:27 AM
detroitdiesel idi's Avatar
Check to make sure battery terminals are clean and ground cables are clean. Need more info though to give better advice
Old Jun 22, 2014 | 10:35 PM
boss4457's Avatar
It doesn't crank at all jus like a humming sound
Old Jun 23, 2014 | 02:23 PM
cviola2005's Avatar
Could be several things. Check positive cable connections at the batteries and at the starter. (My money is one the positive stud on the solenoid and/or the starter housing to the block.) Remove the starter from the block (you don't have to unhook the wires) and check the cleanliness of the mating surfaces. I recommend cleaning and coating with dielectric grease prior to reassembly. Also use dielectric grease or NLGI-2 grease to coat all connections you clean.
GasItOut
35
Jul 22, 2015 01:11 PM
hurriedcoyte
Jun 19, 2015 06:26 AM
Oct 22, 2014 08:10 AM
Oct 10, 2014 08:10 AM
angies04
Sep 29, 2014 04:11 PM
