95 auto trans annoying issue
Old Jun 8, 2014 | 10:11 PM
Dieselhead6.5's Avatar
Default 95 auto trans annoying issue
So here I am again, My 95 6.5td runs awesome, but if I take off too quick (too hard on the peddle) it gets stuck in safety mode aka 2nd gear. I have a high ratio code but no clue how to fix it. Any ideas? thanks
Old Jun 15, 2014 | 09:25 AM
racer55's Avatar
Check out the speed sensors if it's a 4x4-there are 2 in the end of the trans and may not both be good?
Old Jul 10, 2014 | 09:30 PM
It is 4x4, I crawled underneath and found that there is an extra sensor in the trans itself with no wires to be found to plug in to it, it is the second sensor on the side of the housing, the one in front of it is plugged in, and both sensors on the t-case are plugged in. Am I missing some wires or is this sensor replaced by the rear sensor on the t-case?
BTW it is a 4L80E w/ 17 bolt pan. Thanks again.
DieselDan_5.9
Jul 30, 2015 07:05 AM
kydieseltech
May 28, 2015 05:00 AM
apehangerjoe
Mar 26, 2015 03:01 AM
cementhead
Nov 16, 2014 02:58 AM
pv89sj
Oct 12, 2014 02:45 PM
