94-98 7.3L Performance Discussion of 94-98 7.3 Liter Ford Powerstroke Turbo Diesels Related To Performance And Longevity
h2e turbo
Old Jun 5, 2014 | 10:07 PM
hondardr10's Avatar
Default h2e turbo
I am in need of a turbo and I finally found one. A local guy has a h2e turbo and up pipes for a 2002 that I can pretty much steal from the guy. Will this turbo and up pipes work on my obs? What else will I need and about how much $ we talking?
Old Jun 6, 2014 | 12:16 AM
joebob3093's Avatar
Moderator
If its for an obs and its just uppipes and turbo. you might need a drivers side manifold, pedestal, oil feed and drain lines, intercooler set up or a delete pipe and a down pipe. Is it just a stock H2E and who built the pipes?
Old Jun 6, 2014 | 06:55 AM
hondardr10's Avatar
He said its a modded h2e off of a 2002 that they guy before him was going to make a pulling truck so im assuming the guy before this guy built them, said the guy was a welder and fabricator. So in the case it is of a 2002 will the turbo its self work on a obs 1995? Will the up pipes be any good or should I toss them and get obs bellowed up pipes? And how much can a bet a block off pipe?
Old Jun 6, 2014 | 07:32 AM
joebob3093's Avatar
Moderator
The turbo can work on anything if you have the fuel to spool it. The pipes can be used, I have heard SD pipes can be used in an obs with no changes and I have also heard you have to swap manifold
Old Jun 6, 2014 | 07:22 PM
hondardr10's Avatar
Will I have to buy a new pedestal to make it work? And I have stage 2 injectors. If I am buying just a bar bone turbo what would I all need? Like up pipes, pedestal, oil lines?
Old Jun 6, 2014 | 08:20 PM
joebob3093's Avatar
Moderator
If it doesn't come with a pedestal you will need one, stage 2s should be enough to spool it but I don't know. I kit that you buy comes with uppipes, pedestal, oil lines at a minimum. Then some come with a Y pipe, clamps and boots
Old Jun 7, 2014 | 07:49 AM
hondardr10's Avatar
This is a t-4 turbo correct? So I would need something like the irate kit?
Old Jun 7, 2014 | 09:27 AM
joebob3093's Avatar
Moderator
The H2E is a T4i, I'm not sure if irate makes a T4i kit or not but you need someone's kit
avatardvr
18
Aug 8, 2019 12:38 AM
n2brk
Feb 21, 2015 09:05 AM
jrsavoie
Feb 6, 2015 09:44 PM
tumble72
8
Nov 27, 2014 10:31 PM
GreenDieselF
Oct 20, 2014 02:05 PM
