The "D.I.Y. Manual Boost Controller"
Old Apr 30, 2008 | 12:59 AM
2500HeavyDuty's Avatar
Default The "D.I.Y. Manual Boost Controller"
The "D.I.Y." Manual Boost Control
Old Apr 30, 2008 | 07:47 AM
Sea97Stroker's Avatar
That is pretty cool.
Old Apr 30, 2008 | 10:51 AM
not as cool as turning a *** to adjust boost in the cab, but i wouldn't trade the sound for nuttin
Old Apr 30, 2008 | 10:58 AM
RodZZilla's Avatar
WhiskeyRiver took my mind
I wonder if you could hook up a brake bias adjuster from a circle track car to the bolt. I will have to search for an example.
Old Apr 30, 2008 | 11:04 AM
im going to just buy a lockable air pressure regulator, and drill a hole in one of the fittings that is going to the wastegate to help blow off extra boost
Titan Vaper Air Pressure Regulator (Locking), Model# 19303 | Air Filters, Lubricators + Regulators | Northern Tool + Equipment
Old May 21, 2010 | 03:03 PM
harry22's Avatar
it says the site is not available?? Can someone send me the info for this??
Old May 22, 2010 | 03:36 AM
Deezel Stink3r's Avatar
The principle is easy:
An adjustable valve regulates boost pressure to the wastegate.
It bypasses air, so the wastegate does not get the real pressure. As a result of that the wastegate stays closed and you get more boost.
A simple fishtank valve can be used for that.
The better versions have finer adjustable increments or are electronic controlled.
I use the forge Munos, it is delivered with two different springs for a fine adjustment and has a very fine adjustment with a ball valve.
Forge Motorsport | Alloy Fabrication
The electronic controlled:
Greddy - Founded and Driven by Racers
ash23k
Dec 30, 2014 08:31 PM
Crews8r
Dec 21, 2014 07:35 AM
joshkhouse80
Nov 21, 2014 01:17 AM
offroad00
24
Oct 23, 2014 03:28 PM
