Chevy/GMC Duramax 2011 LML Discussion of Chevy and GMC Trucks with LML Duramax Turbo Diesel Engines
nox sensor bank 1 location
Old May 28, 2014 | 04:30 PM
ktaw's Avatar
Default nox sensor bank 1 location
2011 chevy 3500hd duramax setting p2201 code for bank 1 nox sensor but havent had any luck trying to find out where it is located! my automotive program only states its located in the left rear engine on exhaust! kinda bland reference when there is like 5 or 6 sensor back there!
thanks
Old Jul 21, 2015 | 11:19 PM
WarriorWEAPONS9's Avatar
unplug them one by one mark them then you know lil bit of work .
Old Jul 22, 2015 | 10:14 AM
Jet A Fuel's Avatar
Default Nox sensor locations
Not sure if this is what you are looking for :
exhaust-system-description 2011.pdf
For some reason the picture didn't show up in the PDF file.
1. NOx Sensor 1
2. EGT 1
3. Diesel Oxidation Catalyst (DOC)
4. EGT 2
5. Selective Catalyst Reduction (SCR)
6. EGT 3
7. NOx Sensor 2
8. Diesel Particulate Filter (DPF)
9. EGT 4
10. Exhaust Cooler
11. DPF Differential Pressure Sensor
12. Reductant Heater (3)
13. Reductant Pressure Sensor
14. Reductant Level/Temperature Sensor
15. Reductant Purge Valve
16. Reductant Pump
17. Reductant Injector
18. Hydrocarbon Injector (HCI)
Old Sep 1, 2015 | 06:19 PM
jwittea's Avatar
Directly behind the turbo on exhaust discharge, the Nox module is mounted on the firewall directly behind the fuse box on the drivers side, follow the wire over behind the turbo. It's inside the engine compartment if your laying on the cement its the wrong sensor.
Aug 13, 2015 10:10 AM
littletex1
12
Jul 18, 2015 03:41 AM
Zachbishop
Feb 12, 2015 07:12 PM
Nov 7, 2014 05:40 PM
Altonlee
Oct 1, 2014 04:58 PM
