zf5 swap
Old May 26, 2014 | 08:58 PM
91 7three's Avatar
Default zf5 swap
Ive got a super good deal on a zf5 with everything i need to do the swap other than driveshafts. just to be sure everything is there, does anyone know, in detail, what is needed to do the swap?
Old May 27, 2014 | 08:38 AM
91 7three's Avatar
anybody?
Old May 27, 2014 | 09:56 PM
4x4manonbroke's Avatar
cross member, drive shafts, single mass flt wheel, Fairly straight forward..
Old May 29, 2014 | 01:13 PM
91 7three's Avatar
Do you need tcase linkages? Everything else you listed comes with.
Old May 29, 2014 | 01:14 PM
91 7three's Avatar
I think his is a dual mass though
Old May 30, 2014 | 12:43 AM
powerstrokin350's Avatar
I think it's cheaper and better in the long run to swap to the single mass since you'll be there. You do get a bit more low end noise, but once your over 5mph that goes away.
Old May 30, 2014 | 10:44 PM
The T-case and trans W/adapter should have the linkage with it ... if not E-bay it ..
I agree, Go with a flat plate and ditch the DMF ...
and with that said .. i have had mine for 5 years, my disc looks like new, just pulled engine and all out for major work ... So exciting ..
Old Jun 1, 2014 | 04:17 PM
Sycostang67's Avatar
The floor pan section around the shifter is handy to have as it unbolts from the floor. Also need the pedal cage for under the dash which must be from the same generation of truck, 87-91 if referring to your sig truck. It can be from an F-150/250/350, but needs to have the same dash your truck does otherwise it wont fit. Don't forget the clutch hydraulics as well.
Old Jun 1, 2014 | 11:43 PM
Good point ...
Old Jun 4, 2014 | 12:52 PM
91 7three's Avatar
thanks guys. i picked up all that stuff just this past weekend. got the trans, pedal assembly, clutch, flywheel, all the hydraulics, the shifter arm, the floor pan, and the crossmember for 500 bucks. i think i did pretty good on that haha
