Chevy/GMC Duramax 2011 LML Discussion of Chevy and GMC Trucks with LML Duramax Turbo Diesel Engines
2011 Denali lift pump required ?
Old May 26, 2014 | 08:37 AM
tori's Avatar
Default 2011 Denali lift pump required ?
Just picked up a 2011 finnaly replaced the 05 with way to many miles on it , Should I be installing a secondary lift pump, will it help these as much as the older ones. and witch would be the best programmer to install to get rid of the dpf and reductant fluid any help would be apreciated thanks
Old Aug 7, 2014 | 12:00 PM
HeavyDuty204's Avatar
Lift pump will help (even on a stock truck), especially if you plan tuning hot tunes. It'll help keep rail pressure and extra filtration is good.
As for tuning, a lot of guys are running EFI live now. A simple H&S will allow you to delete though (I have one up for grabs if you're interested in that route).
Old Aug 8, 2014 | 08:17 AM
tori's Avatar
Thanks for the help already have a efi on the way and ordered a fass for it as well
Old Sep 3, 2014 | 08:45 AM
PresMax's Avatar
You can get delete tuning on EFI live just have to look for it!
Do all the normal mods and your good to go. Love my efi live. However im not deleted.
Old Sep 18, 2014 | 09:44 AM
Motorops's Avatar
FormerVendor
A lift pump is going to help the cp4 Live a longer healthier life. Also if you end up going with aggressive tuning, it would be needed to supply the high fuel demands in the tune.
Old Sep 19, 2014 | 09:27 AM
tori's Avatar
Thanks for the help am going to order one next week
landon025
Sep 8, 2015 09:21 PM
ctjkelley
Jun 3, 2015 06:01 AM
Renteria1217
Apr 16, 2015 11:38 PM
klein444
Feb 21, 2015 10:33 AM
moneypitk5
Feb 12, 2015 11:01 AM
