Bd compound turbos
Old May 19, 2014 | 03:45 PM
Reeb's Avatar
Default Bd compound turbos
Ok guys ill be picking up a BD compound setup for my 94 in the near future. Question is what am I going to have to do to run them beside 4k gov spring, head studs, have a #10 fuel plate/4k gov spring/4inch exhaust right now.
Thanks in advance.
Old May 19, 2014 | 08:39 PM
4x4manonbroke's Avatar
180 pump ?
trans will Chit its self if you havent beefed it up , Input, TC, VB, good cooler.... the usual
gonna need injectors, tuned the afc, 4K isnt really a must, go 5" you will enjoy the sound if you can get away with it ... Ebay ( Diamond eye 5" 369.00) just sayin
Old May 20, 2014 | 04:36 AM
dieseldemon61's Avatar
I've never really looked into twins so someone might need to correct me, but I think the 12valves need a punched in the oil pan for the second turbo drain?
Old May 20, 2014 | 11:25 AM
94 12valve's Avatar
The early ones yes but some of the later ones have the second oil drain. Also if its a 94 auto should be a 160 pump on that truck
Old May 20, 2014 | 11:34 AM
Would you happen to have a year they started that? Might check mine to see if there is one out of curiosity.
Old May 20, 2014 | 02:34 PM
Yeah, hadn't thought about the oil drain... Can't ya empty them both into one line ?? Or would it just back up into turbo(s)...
Old May 20, 2014 | 04:51 PM
Reeb's Avatar
Originally Posted by 4x4manonbroke
180 pump ?
Trans Is good as for the exhaust I just put it on so really don't feel like installing a new one. Have a set of 300 hp injectors will tune the afc how about delivery valve?
Old May 20, 2014 | 04:53 PM
Reeb's Avatar
Oh this is in my cummins converion I'm running a zf5
Old May 20, 2014 | 05:10 PM
94 12valve's Avatar
If you have a 97 or 98 you may have the second drain its more common on the 98's tho
You can and some have done this with no issues but the correct way to do it is with two drains.
Old May 22, 2014 | 09:27 AM
Reeb's Avatar
My goal is 450ish hp and cool egt. Talked to the guys at industrial injection great guys can't wait!!
Aug 7, 2015 12:40 AM
LadyyD
Chevy/GMC Duramax 2011 LML
10
Jun 1, 2015 05:30 PM
Rockin-coal-01
Apr 7, 2015 07:58 PM
Dustin M
Mar 30, 2015 09:46 PM
offroad00
24
Oct 23, 2014 03:28 PM
