96 PSD getting fuel in the oil
Old May 18, 2014 | 10:51 AM
96pwrstrk4me's Avatar
Default 96 PSD getting fuel in the oil
Did a buzz test and got codes p1275 & p1277. Is this sufficient enough info to detrmine that I need to replace injectors 5 & 7?
Old May 18, 2014 | 02:39 PM
joebob3093's Avatar
Moderator
What are those codes?
Old May 18, 2014 | 03:02 PM
91 7three's Avatar
i dont think fuel in oil is an injector problem. did you compression test it?
Old May 18, 2014 | 07:00 PM
The codes are high to low side open cilinder 5 & same for cilinder 7. Haven't done a compression test.
Old May 18, 2014 | 07:18 PM
joebob3093's Avatar
Moderator
could be Orings or injector cups to get fuel in the oil
Old May 18, 2014 | 11:45 PM
Replaced all o-rings already as well as valve cover gaskets and pig tails. I double checked my solder connections and all seems good. The thing that bothers me the most is that 5 & 7 are on the same pig tail. Injectors at rest are closed, correct?
Old May 18, 2014 | 11:50 PM
I've also been told that if not worked enough that they can stick open which would allow them to bleed fuel through. The truck eas my dad's but he hardly ever drove it like a 7.3 should be. Thus being said, he went strickly off of mileage for PM.
Old May 27, 2014 | 04:20 PM
MOOSE_MACHINE's Avatar
Injector cups would put fuel in the coolant.
O-rings will put oil in the fuel most likely. Maybe a bit of fuel in the oil but I'd be surprised if it was noticeable. I'd start with a compression test.
Old May 28, 2014 | 11:53 AM
Thanks MOOSE. I replace the two injectors and am about to pull them out again due to hydrolock. I guess I didn't get as much fluid out of the cylinder as I thought.
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
bigredcummins
Jan 4, 2015 04:37 PM
