Mazda 2.0 RF in Ranger
Old May 9, 2014 | 09:43 PM
krosnicw's Avatar
Default Mazda 2.0 RF in Ranger
Greetings all, new member here, been lurking in the shadows for a while. I'm impressed with all the innovation I see here. So I guess I'll post my latest project. I've been wanting to do a diesel conversion / mileage getter for a while now and finally got a pretty decent 1990 Ranger regular cab. The engine I'm using came from a Ford Escort Diesel, right now I'm using an extra block I had laying around to see how things measure up. I learned that the transmission from a Mazda B2200 87-93? will bolt right up to the RF engine. And a flywheel from a Kia Sportage will fit on the RF crank and allow use of the Mazda clutch. I know the NA RF isn't the most powerful engine but it's rated at 52hp which is pretty close to the Kubota V2203. We'll see how this goes!
Old May 9, 2014 | 10:34 PM
krosnicw's Avatar
Default Pics
Here are some pics of the beginnings of this project. The first pic is the Kia flywheel bolted to the RF crank. Second is the Mazda pressure plate on the Kia flywheel. Third is the Mazda B2200 trans bolted to the RF. 4th is the starter held in place on the shim plate. One challenge will be mounting the starter. To use the B2200 starter on the RH side the oil line and exhaust would have to be modified. To use the Escort starter on the LH side a section needs to be cut out of the bell housing and the starter needs to be set out approx .400 in.
I'm considering making a starter bracket that is also a spacer plate and mounts to the block.
Attached Thumbnails Mazda 2.0 RF in Ranger-img_0740.jpg   Mazda 2.0 RF in Ranger-img_0743.jpg   Mazda 2.0 RF in Ranger-img_0746.jpg   Mazda 2.0 RF in Ranger-img_0744.jpg
Old May 13, 2014 | 08:09 AM
Evenglass's Avatar
Interesting install. I look forward to seeing how it works out. Where would one find that engine?
Old May 14, 2014 | 05:33 PM
krosnicw's Avatar
This one is from a Ford Escort diesel. They were also an option in Tempos from I believe 84-87, and in Mazda 626's. I seem to stumble across them and have 4 of them right now.
Old Jan 26, 2023 | 11:22 PM
Clappedout84's Avatar
Default Needing a flywheel and clutch for my 84 ford escort
can't find much info on them and this is the best thread i could find would you have a link to a good flywheel and clutch kit for my car the flywheel has massive clatter never owned one of these and I'm having trouble even finding parts
Aug 26, 2015 10:40 AM
Jun 12, 2015 04:30 AM
Mar 24, 2015 05:40 PM
Dec 5, 2014 07:50 AM
Nov 27, 2014 08:00 AM
