1995 12v in a 1979 CHEVY K-30
Old Apr 21, 2014 | 04:05 AM
esowell337's Avatar
Default 1995 12v in a 1979 CHEVY K-30
OK guys. I've had the 79' K-30 for a while, I love the truck, but hate the fuel mileage, and it is kind-of a turd. 454 with an sm465. Screamin rpm's at 65 mph, maybe 4 mpg- unloaded. It does however start EVERY time with no persuasion or manipulation. I have bought a 95 12v Cummins, and I plan on utilizing it with a 47rh, which means a whole big bunch of swapping and changing and light fabwork.
I started the motor on my engine hoist after chasing water out of the fuel system, changed filter, bled air/ water at injectors, etc. it ran great!! Then I shut it down. The next day I tried it, I can get good fuel pressure to the p-pump, but nothing gets to the injectors or the deliver side of the p-pump. I cracked a few, no water air or fuel came out. Cracked the fuel inlet and sprayed fuel everywhere. cracked the OFV and not a drop. I will take any advice given, I am NOT a mechanic, but I am smart enough to listen to those who are. Thoughts?
Old Apr 22, 2014 | 07:43 PM
six speed's Avatar
is the fuel shut-off silenoid working? it's the little canister looking thing toward the back of the pump attached to the afc housing with 2 bolts that has some short wires coming out with a plug on the end of them. it should cycle up and down as it gets power or not.
Old Apr 22, 2014 | 08:01 PM
esowell337's Avatar
Sorry I forgot to mention that, the solenoid isn't there, I manually shut it down with the lever by hand. I've been at work for two weeks since this happened, but after doing a bit of research I fear that the internals of the lever may not be actuating when flipping the lever. Any chance of that? And would I be able to fix it at home if that's the problem? I go home in the morning, and I will have 2 weeks to work on it. I just want to get it right before I start throwing the motor in the truck.
Old Apr 26, 2014 | 09:04 PM
six speed's Avatar
i don't know. sorry. i've not ever had to mess with this.
ItsAChummins
May 15, 2015 05:02 PM
Snoobly
Dec 11, 2014 11:59 AM
Dec 3, 2014 09:40 AM
Oct 30, 2014 11:50 AM
Oct 16, 2014 07:10 PM
